what cam with turbo?
Old 09-03-2004, 09:07 AM
ls1boost's Avatar
Default what cam with turbo?
hey i just wanted to know what is a good cam to run with a turbo application and how much boost do you think i will be able to run?
i have:
3.095 pistons
6.125 rods
stock crank
aluminum intake
port and polished ls1 heads
ARP bolts
custom exhaust
STS turbo kit
Old 09-03-2004, 10:34 AM
PREDATOR-Z's Avatar
LPE
GT2-3 >>>>207/220, 0.573/0.580 117.5lsa
Old 09-05-2004, 02:05 PM
ls1boost's Avatar
bump!!!!!
Old 09-05-2004, 05:12 PM
FASTONE's Avatar
That will depend on your static cr,and a lot of other things.Ask the guys in the forced induction section.
Old 09-05-2004, 05:47 PM
Another_User's Avatar
Originally Posted by PREDATOR-Z
LPE
That looks like a good one. You want more exhaust duration and lift, and pretty sharp ramp rates, without a lot of overlap. You will be able to get the air anf fuel in there. You just need to make sure it doesn't wind up blowing right out your exhaust valve.
Old 09-05-2004, 06:13 PM
Kaneman's Avatar
I have the STS Turbo kit also and a 370 setup with a 220/224 581 115. APE says that has made them great power.
Kane
Old 09-05-2004, 07:12 PM
Ragtop 99's Avatar
Post this is in the Turbo and S/C section. Maybe my memory is off, but I recall that some people use small reverse splits for their turbos.
Old 09-05-2004, 07:35 PM
As they should! Heck, this is about the only application the "Old Man Cam" makes sense in.
