Modified LS1 Rocker Arms(new Bearings)
Old 09-03-2004, 10:51 AM
Nasty N8's Avatar
Default Modified LS1 Rocker Arms(new Bearings)
OK I know some of you out there do not use aftermarket rockers simply because they are a little heavier over the tip. Well we are going to offer a set of modified stock LS1 rockers done by Harland Sharp. The new rockers will have a new trenion and new bearings with provisions for clips so there is absolutly no chance the bearings can come out. They will use the stock rocker bodies. We will offer them on an exchange basis-send in your rockers we will send you a set rebuilt or as a core charge. We can also offer different ratio when it is done change your stock rockers to a 1.8.
Stock LS1 rockers
Harland Sharp trenion
Harland Sharp bearing assembly
offered on an exchange or core charge basis
Let me know what you think and if your interested. Could be available soon.
Thanks and have a great weekend
Nate
Old 09-03-2004, 11:02 AM
PREDATOR-Z's Avatar
When it comes to clearance issues this would be awsome!!!
How soon??
How much??
Count me in.
May I recommend you change heading on this thread like:
CURE FOR SPILT BEARINGS ON STOCK ROCKERS.
Old 09-03-2004, 11:46 AM
Nasty N8's Avatar
What do you mean the Harland Sharps have zero clearance issues already? I am not sure how much just yet but could be available very soon.
Nate
Old 09-03-2004, 11:52 AM
Nasty N8's Avatar
Why would you go this way over a new set?
Old 09-03-2004, 12:14 PM
PREDATOR-Z's Avatar
Nate
https://ls1tech.com/forums/generation-iii-internal-engine/189081-harlanf-sharp-1-8-rr-junk.html
https://ls1tech.com/forums/generation-iii-internal-engine/177306-broken-valve-spring-retainer.html
https://ls1tech.com/forums/generation-iii-internal-engine/141374-installed-harland-sharp-rockers.html
I wouldn't call these ZERO issues
Because of the not so Zero issues.
HS would be better rockers, lighter, twin-shaft (no twist), beautiful (see them once a year or at breakdown),roller bearing nose, BUT a little heavier on that nose.
However, I'll have AFR's and I would hate to start grinding, measuring, HOPING they would fit. (Heads or VC's)
A stock rocker that doesn't splill bearings would not make me think twice.
Also bear in mind that my "small" cam will not see more than 6600rpms.
Old 09-03-2004, 12:24 PM
Nasty N8's Avatar
Yes nothing fits on a 98 head they will be good for that. I have installed probably 50 sets on 99+ and truck heads and never had a set that hit or needed clearancing. I have had a couple of people tell me they have? I guess every casting is different but then why have I never run into it? We will also be testing on the AFR`s soon to see the clearance on those heads.
Thanks for the info and you could be the first with a new set of bearings in your rockers.
Nate
Old 09-03-2004, 01:50 PM
nuzee's Avatar
I would be interested if the price was significantly under the price of purchasing new SLP 1.85 rockers.
Here’s my reasons:
1. Obviously the better bearing & 1.8 ratio change.
2. No clearance issues.
3. Longer life span vs. aluminum body rockers for street use.
4. Allows me to run different ratios on the intake vs. exhaust when used with stock rockers.
5. I’ve heard that stockers are lighter over the valve than some aftermarket.
6. I have a set of stock rocker arms on my shelf collecting dust. Did I mention price?
I sure hope this doesn’t go the same way as the 2-piece timing cover did. I was getting all hyped-up about being able to change cam timing easily and then I saw the price, ugg.
Price will again be the BIGGEST factor in my decision to go this route.
Old 09-03-2004, 07:17 PM
GrannySShifting's Avatar
i defintely sent an email to Jeff at HS about doing this and a couple otehr projects for me a couple weeks ago!
Old 09-03-2004, 10:47 PM
Mike94ZLT1's Avatar
What price range are we looking at, and will they be available in the stock 1.7 ratio? I'm interested if the price is right!
Old 09-04-2004, 02:06 PM
PREDATOR-Z's Avatar
Originally Posted by pdd
with my afr heads i had to grind every one of the HS rockers
Well that pretty much answers my fears.
So yeap, I'll be really interested in the stock rocker mod.
Old 09-04-2004, 03:30 PM
C4VetteLS1's Avatar
price?
Old 09-04-2004, 11:40 PM
max's dad's Avatar
Sounds good!
Old 09-05-2004, 10:30 AM
PREDATOR-Z's Avatar
Nasty,
Is this thread a marketing research or are you guys going to devellop this for sure?
If so could you give us a close ETA of these? Would you say before Christmas for sure?
And apparently cost is a big factor in peoples mind $$$$?
Old 09-06-2004, 05:49 PM
Jeff tooled up a bearing assembly for a stock rocker last Friday I think it was he said. They (to my knowledge) arent part numbered and selling just yet, but there is at least one
Old 09-07-2004, 10:29 AM
Nasty N8's Avatar
Either as a kit with all the parts, tool and instructions. With a press the customer can install these himself.
Total rebuid kit stock ratio $210.00
Or send in your rockers on an exchange basis.
Kit installed stock ratio $260.00
Nate
Old 09-07-2004, 10:38 AM
PREDATOR-Z's Avatar
That is not bad,
How much for the cores (for less down time)?
Old 09-07-2004, 12:26 PM
94form2000z's Avatar
Sounds like a very good option to adjustables.
Old 11-01-2004, 03:10 PM
nuzee's Avatar
Excuse me for bringing up an old thread, but I would like to know the status on the rocker ratio change. Anybody know or have had it done?
Old 11-01-2004, 04:18 PM
Nasty N8's Avatar
These are being done now. I have not personally had anyone request the ratio change yet but I do believe they can do it for a extra charge. I will call them in the morning and ask for sure.
Nate
Old 11-01-2004, 04:23 PM
Viper's Avatar
Nate,
How much are these if I send in the core? I didn't see anything on your website.
I just ordered the LPE shortblock for $2100 and I'm waiting on AFR 225 results before deciding on heads over the winter, but at 60K I'd like to replace my stock rockers with these from you possibly.
Thanks
John Tokar
Quick Reply: Modified LS1 Rocker Arms(new Bearings)
