Fueling & Injection - in tank hose??
View Full Version : in tank hose??
L-EATER
09-04-2004, 08:15 PM
Ok, I recently replaced the stock in tank pump in my truck with a home brewed dual pump setup. After putting it all back together the gas gauge went nuts so I had to order a new sender and I just got around to installing it today.
Anyways, I used a piece of high pressure fuel injection rubber hose to hook the pumps to the module (in place of that factory flex tubing) After less than 2 weeks that hose has deteriorated and become soft. The outer layer was separating and was swollen quite a bit. My question is this....what type of hose is capable of being submersed in gasoline without failing?? Is the factory flex tube available separately? I needed to get it back together and all I had was some power steering hose so thats what I put it back together with for now.
I need recommendations on what to use before that p/s hose breaks down.
cablebandit
09-05-2004, 04:48 PM
lol...i went thru that shit a lot!!!!!!! Go to a hydraulic hose/fitting place...tell them what size you need....pumps are 5/16" and that it's for gas...you will be set for just a few bux if not free. I made my tee from pieces at the hydraulic place...cost 9 bux i think...5/16 tees to the pumps and the out to a 3/8 to the pump housing
L-EATER
09-08-2004, 08:04 AM
Cable-so you are saying that hydraulic hose is ok to submerse in gasoline? My application is 3/8" on both ends, so nothing special is required.
I contacted racetronix and they wouldn't sell me the flex line so I am not sure where to turn at this point.
Anybody else have any suggestions?
Racetronix
09-08-2004, 05:56 PM
We said "Sorry, this item is not available."
We did not say that we were not willing to sell it to you!
There are many variations available for flex lines.
We stock only the sizes used for in-house production ONLY!
Flex hoses come in boxes of 1000+.
