whistling/sucking noise after cam swap
Old 09-06-2004, 04:38 PM
2 SLOW's Avatar
Default whistling/sucking noise after cam swap
any ideas of what it could be? thanks
Old 09-06-2004, 09:30 PM
SeeYaSucker's Avatar
not sure, but you could check the PCV hose connections on the valve covers and the lines itself, one could have broke, or a vaccum line.
Old 09-06-2004, 09:35 PM
Another_User's Avatar
That is the exact same noise my wallet makes whenever I have a problem during working on my car! Just kidding. Are there specific times it happens, or a specific area of the engine bay it is coming from? Definitely check any vacuum lines you disconnected.
Old 09-06-2004, 09:59 PM
chpmnsws6's Avatar
or u could just be hearing ur intake sucking air in
Old 09-06-2004, 10:00 PM
Onyx Z's Avatar
I bet the PCV elbow at the back of driver's side valve cover is cracked. I did the same thing when swapping my springs, so I have a whistling motor too. It's most likely a vacuum leak.
Old 09-06-2004, 10:18 PM
Nakoz's Avatar
What are the specs for the cam you are using?? Could tell us the PV clearance.
Nakoz
Old 09-06-2004, 10:57 PM
2 SLOW's Avatar
F13, 230/232 .591/.585 112+4
i'll check the elbow
Old 09-06-2004, 11:00 PM
Formerly 4mulaJoe
LS1x2's Avatar
vaccum leak
Old 09-07-2004, 02:31 AM
DONAIMIAN's Avatar
So your car finally got some *****.
:hides face in shame because everyone in houston has a bigger cam than me:
Old 09-07-2004, 11:28 AM
2 SLOW's Avatar
still slow and down on some HP
