Shifts?
Shifts?
I was wondering, if i where to drive the A4 and go 1-2, and 2-D, and D-(D) what MPH i should shift at?
this just so i can get a good goin if i am on the highway and i want to drop a gear so I have some pull
so basically what MPH should i shift out of 1st and 2nd? Thanks for the help
Dude, your best bet is to just leave in OD. You need to find the right MPH that will get you the right computer controlled down shift you want if you are going to race, I know with my 3:23 geared car on the highway I need to keep it under 70mph to get a wicked 4th to 2nd down shift. If you are going to manually shift watch the RPM's not MPH....and you better shift 600-700 RPM before red line. Leave it in OD and go buy a 3200+ stall to cure your problems
If you don't want to change stock, try a performance air filter.
