How often do your fans run??
Originally Posted by ataylors
It seems mine are on all the time trying to keep the temp around 170* with a 160* stat..
Originally Posted by Patman
Your fans might sound like they are on all the time, but once you get up to about 35 (or is it 50?) mph they will shut off.
I am sure it is not 35 as that would make them off all the time. On the freeway with the A/C on doing 80mph I was seeing as high as 190*
I was stuck in brutal traffic on my way home yesterday, but since my fans run all the time at low speeds, my coolant temp never went above 194F. My oil temp never went above 201 and my trans temp never went above 180! So it's definitely beneficial.
Moderator
My setup has low-speed fans on pretty much full
time and high speed on under any kind of hard
driving.
If you're trying to hold a 175F ECT you're probably
trying to make a 150F tank whilst sitting on 120F
asphalt. Need a lot of airflow to do that. Cooler air
helps. I could not hold 180F temps at 80MPH and
fans running, during my Georgia trip in July with
the A/C on. A/C dumps a lot of heat onto the rad.
driving.
looks like I am going to have to swap the radiator
Moderator
The thermostat prevents overcooling. More airflow,
more radiator surface area, all just give it more room
to work. Thermostat sets the minimum coolant temp
but only sets the max if everything else in the chain
is pulling its weight.
I am not trying to overcool it. I am trying to keep it from hitting 200* with the AC on and keeping it from having to run the fans every 2 seconds on a warm day
