tsp 231/237,a4,3.42
Old 09-07-2004, 11:39 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
Default tsp 231/237,a4,3.42
what streetable stall it best for this combo?
Old 09-07-2004, 11:40 PM
cyphur's Avatar
edit: after lookin into it some more(i have an m6, so yea) you'd prolly be better off with a 3800. stick with the 3.42s or go with 3.73 gears, and that will help make up for the 'verter bein a little looser. you'll have to ask some of these auto guys on which tc is more 'street friendly'.
if you post this in the automatic tranny section, you might get a better response. just a thought.
Old 09-08-2004, 12:47 AM
Honez's Avatar
I may be out in the weeds on this one but the moment you say "streetable" I start thinking lower. If your driving it on the streets a lot then I wouldn't go above a 3000 or 3200 max.
Old 09-08-2004, 12:57 AM
LittleBoyBlu99's Avatar
Try Yanks SY4000 you will love it on the streets or track!
Old 09-08-2004, 05:00 AM
rstmeredZ's Avatar
Their website calls for 4000.
Old 09-08-2004, 07:54 AM
Z'mnypit's Avatar
Mods in sig. Mines not that bad. It has some bucking between 35-40mph. but I just drop it in drive. Then shift to overdrive Once I get going. Other than that it drives great.
Old 09-08-2004, 08:50 AM
gettinthere's Avatar
If I had an auto I'd go with either a Vigi 3800 or a Yank 4000. Vigi does allow one free upgrade if you feel you went too small don't they? Anyways, either one of those should suit you just fine.
Old 09-08-2004, 10:22 AM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
I'm running a TCI Competition 3800 in my '02 SS with heads/cam and 3.23's, and it's great! I took it on an 800-mile trip this past weekend, and I managed to knock down 25.5 MPG! I drive my SS everyday, and the 3800 is very streetable for me. However, I've been known to run a 4600 stall in the past, so the 3800 is more than streetable for me. FYI, I'm running our 231/231 112 LSA camshaft in my SS, and it works great with the 3800. My shift extensions with the 3.23:1 gearing are at 5,000 RPM, so you would be right around 5,100-5,200 RPM with your slightly steeper gearing. You could even run a TCI SSF 3500 if you wanted to. It would retain plenty of drivability for the street, but a higher stall will benefit you more at the track.
Feel free to give me a call or e-mail me at trevor@texas-speed.com if you have any other questions or concerns. I'll be more than happy to help you pick the right torque converter for your setup.
Trevor
Texas Speed & Performance
__________________
Old 09-08-2004, 11:30 AM
blkmgc1's Avatar
i have a vig 3800 and i love it works great on the street.mpg aint **** though but very steetable and if you up the gear you will really love it.3800 is a very good stall speed due to the fact that it's not to high and not to low also mines grabs like a 2500 stall unless it's at full throttle it grabs really early hope that helps.....
Old 09-08-2004, 01:45 PM
Retired Street Racer
Matt D's Avatar
hmmmm...makes me kinda rethink my setup...tsp 231/237, tci 4400, and stock 2.73 gears, lol...mine is not a daily driver though
Old 09-08-2004, 02:49 PM
thanks for the quick responses guys. i'm going towards a 3800, the cam should like that hopfully.
Old 09-08-2004, 08:11 PM
MONGOOS's Avatar
Not much for comparison but I have a Vig3200 and a 224/224 114 cam and I can't complain a bit as far as streetability goes. I want to up the stall to a 3800 and go with a bigger cam as wekk in the future... be my test bunny!
Old 09-08-2004, 08:40 PM
blkmgc1's Avatar
i have a 236/232 and 578/571 on a 112 lsa and the verter does'nt mind it at all if that will help ya
