please...need help with paint chip.
i recently had my rear bumper cover re-painted. 2 days after i got the car back, i was trying to remove my old catback. while wrestling with it, one of the exhaust tips smacked up into the bumper ( cutout section on t/a bumper,) and much to my dismay, took a penny sized chip of paint with it. since the chip can't be seen unless you actually get down and look for it, i tried covering it with touch up paint. of course, this didn't work as the paint has cracked/flaked a little more from the original spot, making me feel like even more of an ***. is there anything i can use to stop the spread of this? thanks for any help.
Fiery Features Director
Sounds like your touch up paint isn't sticking. I would suggest starting over... Clean the section really good with rubbing alcohol. If the area is small and you don't want to risk messing up the paint around it, use the end of a pencil. Put the sandpaper around the eraser and sand the area with that. Once you have the area sanded down well, clean it again. Use a cotton swap to fill the area with a thin layer of primer and make sure that you fill any areas that are still lifting. After a hour or so, you can sand the primer down with a less harsh sandpaper. Then apply a thin coat of paint with the swab. Let it dry and apply another layer of paint. You are going to have to wait a few days (atleast 3-4) and then you can go over the spot with rubbing compound. Then wash and wax after some more time passes. It might be alot of work but it will leave your paint looking like new and will keep the paint from peeling further.
since the spot isn't in plain view, i was planning on using touch-up paint. my main concern is to stop any further damage. if something else is more appropriate, i'll use it. i just want to get it fixed. this chip went all the way to the black plastic. i'm almost too embarrassed to go back to the body shop, as this will be the third rear bumper replacement/re-paint in 1.5 years!
