HP rating:need help
Old 09-10-2004, 11:32 AM
StangKillaLS1's Avatar
Default HP rating:need help
I was wondering if anyone might be able to help me out with a guess on HP rating on this set up
Stage 2 Heads (patriot performance or MTI stage 2 heads)
Comp cam xtreme energy cam
LS6 intake
80MM throttle body
MTI lid w/K&N filter
SS ram air hood
Program chip
pully kit
Hooker long tube headers w/y pipe
Magnaflow cat back exhaust
50 shot of NOS (wet shot)
hollowed out cats
TCI street fighter torque converter 3,000 stall
3.73 gears
F.A.S.T fuel system
Nitto 555R (275/40ZR17)
would that be enough for around 500 RWHP???? or should i also get a 383 Stroker kit
Old 09-10-2004, 12:12 PM
PREDATOR-Z's Avatar
Comp cam xtreme energy cam (?? which one? TR 224/114lsa will do)
LS6 intake
80MM throttle body (just port original)
SS ram air hood (just for show)
Program chip (LS1 require dyno tuning or Edit) no chips
pully kit
50 shot of NOS (wet shot) (you'll need a 100 at least)
hollowed out cats
TCI street fighter torque converter 3,000 stall (Higher stall 3500 min)
3.73 gears
F.A.S.T fuel system (Racetronix PnP+ 30 lbs SVO inj.)
Nitto 555R (275/40ZR17) (Good luck hooking)
No need for stroker if 500 rwhp is with N20- N/A yes you'll need stroker
Just some corrections in red
Old 09-10-2004, 12:13 PM
WS-Sick's Avatar
With that 50 shot I would say you should be around if not over 500 RWHP.
Forgot you were an A4...but you should still be around it. You'll be fast regardless.
Old 09-10-2004, 08:09 PM
jrp
SN95 Director
jrp's Avatar
i never see the point of these damn threads. install the **** and then dyno tune. every car is different and what you should dyno and what you [b]do[/d] dyno could be totally different.
