Single Turbo V6 Dyno Graph
Details:
1989 Turbo Trans Am. We can only run up to 27psi right now because of a the wastegate. We need to pickup a new spring so we can run 30+. Full custom single turbo setup done by TTP.
Car runs pretty well, havent gotten any passes on the new setup. We clipped a 10.4 @ 129 with blowing a headgasket on the top end. This was only running 24psi launching with a loose converter on low boost. The setup should see 9's with full weight/interior + rollcage. Launching on the brake @ 20psi is fun too, george roasted the tires outside... our neighbors should love us between tonight and tomorrow's dyno day
spec's
areomotive pro series fuel pump, custom sumped fuel tank with 2/ 8AN feeds to fuel pump, 8AN feed line ,6AN return line, 160 pound per hour injectors, paxton automotive adjustable fuel presure regulater, fast systems fuel injection with wideband 02,accufab 75 mm throttle body ,race ported intake manifold with exhaust gas reculator milled out and welded up, pte upper intake,rjc plate , m&a race ported heads with stainless manley valves 1.94 intake 1.60 exhaust ,ngk fr5 spark plugs ,4.005 bore je racing forged pistons ,je racing moly piston rings ,corillo h-beam rods ,buick motorsports 3.58 stroke crank ,jw wheel flexplate ,sfi balancer ,comp cam solid roller .572 intake lift .572 exhaust lift duration at .050 230 deg intake 230 deg exhaust lobe seperaton 112 ,arp head studs arp main studs , stage 2 4.1 block ,four bolt mains, stock oilpan with custom pickup, tta oil cooler ,kooks custom 1 5/8 headers ,kooks 3inch downpipe , innovative turbosystems ball bearing 85mm turbo with.96 exhaust housing ,tial 46mm wastegate,innovative turbo systems electronic boost control ,mufflex 4inch exhaust with borla 4 inch xr1 race muffer,presision turbo & engine intercooler core ,TTP 3 inch intercooler pipes ,turbonetics silicone intercooler hoses , voss 3inch intercooler clamps , permacool fan in front of intercooler ,b&m trans cooler ,performance transmission service 9inch pro-torque 4000 stall,hi-pro 2004r by Eric Schertz with all performance transmission service billet and hardened components ,performance transmission service roller kit ,performance transmission service bat brake , performance transmission service 2quart extra aluminum pan ,lakewood rear drag shocks 50/50 ,lakewood front drag struts 90/10 , lakewood rear control arms ,lakewood pan hard bar ,ebaich drag launch springs with airbag ,random technology torque arm ,random technology rear control arm lowering kit ,8 point roll cage by wild rides ,wild rides subframe conectors ,simpson cam lock belts , performance automotive bolt in tubular k-member russell braided brake line kit a/c eliminator pulley ,line lock , window net ,moser 12bolt with 3.50 gears and spool,inland empire driveline alum 3.5 inch driveshaft
Originally Posted by turboo16
is the car still for sale ? you can get more out of it! stage 2 right? are they GN1 style ported heads?
Nice HP, but either there's a problem with the dyno graph or the combination is screwed up somewhere. The TQ and HP should not be peaking within 300 RPM of each other. And 220 Ft/Lbs of TQ at 4000 RPM is also an indication that the combination is off. From the looks of the graph it would seem you're in need of a 6000 stall converter which is too big for a TR motor, even a stage 2.
I think the 85 mm turbo might be a bit too large for the engine and maybe the cam's a bit big and you're bleeding off cylinder pressure. An 85mm turbo will flow enough to go low 9s to high 8s.
I ran 11.3s at 126 1.88 60' in my TR with an 1/8 MPH of only 97. The 2600 stall converter killed my 60' and 1/8 but after the 1/8 the car woke up and then I started getting lean pops through the intake cause I was running a single 307 pump. With 70 psi of fuel pressure that pumps volume began to drop causing the car to go lean and pop a head gasket.
My combination was nowhere near as radical as your T/A's. Stock 109 block, .020 JE pistons, a ESP stage 4 cam (baby cam), stock rods and crank, stock rockers, stock ported heads, stock ported intake, stock untouched TB, stock ported exhaust manifolds, CAS V1 intercooler (old style), T63e turbo (3 bolt with 3" compressor housing), 3" ATR downpipe and 30 psi of boost. The converter cost me 3 mph in the 1/8 (126 mph in the 1/4 would yield 100 mph in the 1/8) and the lean popping (popped 4 times in 3rd gear) cost some mph aswell. With a looser converter the car should have run 10.7s at 130. Car was full weight with bone stock suspension and stock wheels w/27x10 slicks.
I see Eric built the tranny, did you guys discuss the combination with him?
george
Even starting off boost, I would have expected that by 5000 rpm you would be at full boil if the turbo was the right size. Peak tq at 6000 rpm for a car that starts to drop a lot at 6500 indicates something in the combo isn't right.
For a drag car, getting the torque up would help a lot. Of course if you race from a roll, you probably make a ton of money.
BTW, awesome HP
BTW, awesome HP
5600 to 5800 i hit full boost 24psi the i went to 27 at the end of the run i need a tighter wastegate spring to make the boost go higher and im going to run a dump pipe tobe able to spool faster on the trans brake i get 20 psi of boost in 3-4 seconds for my launch spools pritty fast for a big turbo also remember im a no lock up converter so its hard to do a pull down low
george
george
