Need Dyno Results for 2000 SS's
I'm trying to compile some data on the kind of numbers stock or slightly modded 2000 SS's are putting down on the dyno since I don't have one in my area. I've seen a lot of numbers for 01-02 but not for the 98-00 models. I would expect the numbers to vary slightly due to the different cam timing and LS6 intake on the 01-02 cars..Mine is stock with a whisper airlid and LM exhaust.
If you have data to share, I'd welcome it..thanks..
BTW, I believe to convert rhp/rwtq to flywheel values, you add 15% to the dyno figures..does that sound right?
