blown head gasket. how can you tell?
Old 09-13-2004, 09:50 AM
camaross383's Avatar
Default blown head gasket. how can you tell?
I have a small pool of rusty water on my passenger side head, right where the top of the head meets the block every time I drive the car. about once a month. It doesn't smell like coolant, but I don't know how rain water could get there. Anyone else have this happen? Is my head gasket blown?
Old 09-13-2004, 11:16 AM
Boostaholic's Avatar
Have you checked your oil for coolant / water?
Old 09-13-2004, 12:36 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Using coolant?
Make sure that the coolant crossover pipe is not leaking.
Old 09-13-2004, 12:41 PM
ther is no coolant in the oil, it's not seeming to use any coolant, but I haven't checked the crossover pipe.
Old 09-13-2004, 12:42 PM
LSUxBlake's Avatar
Usually you'll see a little smoking out the exhaust..........
Old 09-13-2004, 11:22 PM
ace68's Avatar
do a compresion check near the questionable area? look at your plugs? any bubbels in your coolant? do a preasur check on your cooling system make sure it's full check for drips while it's under presure
Old 09-14-2004, 06:53 AM
Billiumss's Avatar
When my head gasket was bad, I had a very slight white smoke on cold starts, you could barely see it and just thought it was condensation. My coolant level would SLOWLY go down, adding a small amount every few days/weeks.
At first I thought my system was still trying to get the air bubbles out after my electric water pump install. I got the car on the dyno and my numbers were down. After the 3rd start up on the dyno, a TON of white smoke came out then. We let it cool down on the dyno and sure enough my coolant was low.
After I pulled my heads you could see the spot where it was going into the cyl. It was about 1/8" wide!
Old 09-14-2004, 10:34 AM
LS1Tech Co-Founder
Top up the radiator when the car is cold and monitor the levels. If you put in say a pint after a week it's going somewhere.
I had a hose that leaked, make sure to check other stuff.
