Whats the compression of MTI 2E heads?
Originally Posted by MTI
Stage 2E Cylinder Heads
Complete hand porting of intake, and exhaust runners for excellent flow volume & air speed with major bowl work performed. Ferrea 2.02" stainless one piece intake valves, and 1.56" exhaust valves are used in the factory valve seats. High performance dual valve springs coupled with our custom lightweight titanium retainers and specially machined spring cups offer the most stable, and reliable valvetrain. These heads can be milled .030" to increase the compression ratio by 1/2 of a point. This is an excellent street cylinder head with flow numbers exceeding well over 300 CFM on the intake runner and 210+ on the exhaust side. Each set of cylinder heads will come with their own individual flow sheet. If you're looking for a great cylinder head at a great price, look no further. Available for LS1, LS6, LQ9 and all 5.3L truck castings. See the flow sheet attached to this page for flow data.
Originally Posted by PREDATOR-Z
I got that from their site, can you believe what you can do by searching?? Freaking ammazing aint it?
"These heads can be milled .030" to increase the compression ratio by 1/2 of a point." which is true, but does not say what the exact compression of their heads are to start with. I'm guessing around 10.6? Anybody know for sure?
"LS1, LS6, LQ9 and all 5.3L truck castings."
I'm sure you know they all have different CR unmilled
Perhaps you should state what heads are you thinking of, Oh wise and knowledgeable Master.
Originally Posted by Magred2001vette
UPDATE...I just talked to MTI and they said an unmilled MTI stg 2E 5.3 head has a CR of 10.5
