Finally broke asomething after a year 1\2
Went to SCD tonight(48 deg,65% hum,30.11 baro) -817 DA <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> for some more testing on ET Streets. Ran in the same setup as the Spring Break race that went 10.51@135 with 3000+ DA.
First run 30% starting power level with 2.5 second time in to full power at 5000 RPM launch and 850 psi bottle pressure:
10.18@137 w\1.44 60'(also slight head wind)
Hooked ok on that pass-let the bottle heat up to 900 psi,hard to keep up in cold weather <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I pushed the starting power to 50% with 2 second time in and left at 6000 RPM.
Dumped the clutch and she left with a rage 1.39 60'(best so far on ET Streets) shifted to 2nd and the car shook like crazy. Eased to the return road and loaded on the trailer.
Once loaded looked under to acess the damage-RIPPED the top torque arm rodend\bolt clean out the mounting bracket,bolt still in the rodend <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> -Random Tech torque arm setup.
Oh-well not bad for the abuse from many 1.47 on the motor and 1.37 60' on 28" slicks .
LS1Tech Co-Founder
Re: Finally broke asomething after a year 1\2
Well, at least thats a cheap and easy thing to fix. I've seen a couple of those adjustable random techs get shredded at the track. Probably should go with something heavier duty, like that Madman setup. I've never seen one of those get tweaked.
Tony
Tony
I can shift faster than you.
Glad to hear it was something simple. When you called and told me what happened, I thought you did what I did at the TR shootout and broke the bolts off the tq arm bracket.
1.39 60' on ET streets is impressive. <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> I guess I should consider going back to SCD if they prep the track like that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jason
Jason
LS1Tech Co-Founder
At least you have not bent the R/T tq arm, it's a really good piece, I am sad to be getting rid of mine...
How come you are not running 1000 bottle pressure?
"The Drag Racing Director"
Hey Allen,
Sorry to hear about your problems. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Give Madman a call about his TQ arm. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Maybe you need to ask him about the "Coach" Star Wars Mod! <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Coach
<small>[ April 10, 2003, 08:33 PM: Message edited by: Coach 02 M6 Z/28 ]</small>
Coach
i had the same problem. i only had a Random Tech TA on my old 6 speed combo for about 3 months and majorly elongated the hole the the top rod end bolt goes through
Allan, give me a call on Monoday. I can give you the number to my chassis guy, he is making torque arms for LS1 cars right now. Tom is getting one put in his car as we speak. Let me know if you are interested.
Chris
Chris
LS1Tech Sponsor
Allan if you want the best torque arm out there . The most adjustability AND strongest let me know. I can set you up with the new OUTLAW arm. It has more adjustability than the race version and it is 3 times stronger but only a 1/2 pound heavier. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Can any other t/a put down consistent 1.2s 60ft and run mid nines????? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Damn Allen that blows but atleast it was not something to expesive 1.39 60 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
wow! i have pulled 1.37 60's with my BMR extreme duty, at 3625ish race weight without a problem! i know how hard a 6 speed can be on parts! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
i am sure what ever you put in will work just fine!
The torque arm we are doing for Tom Kempf also has adjustments at all attaching points. One key thing about our arm(IT USES A BRONZE BUSHING, WHICH IS SELF LUBRICATING IN THE FRONT MOUNTING POSITION)we found that a heim joint wont assist in keeping the car straight because of its ability to roll from side to side. When we get to Bowling Green, I will bring an extra one for anyone who would like to try it.....Chassis1
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong> Well, at least thats a cheap and easy thing to fix. I've seen a couple of those adjustable random techs get shredded at the track. Probably should go with something heavier duty, like that Madman setup. I've never seen one of those get tweaked.
Tony </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">MADMAN's new Torque arm is 1/2Lb lighter and 3x's as strong as his old set up...stay tuned for a write up on his new TA with pics!
Thanks for all the warm responses and suggestions <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Ive been real happy with the Random Tech arm over the last 2 years with all that Ive put to it.
Jason-I was impressed how SCD was hooking. Going to be going to SCD on wednesday more often.
PSJ- got tired of waiting on the bottle to warm up,I normally run at 950-1000psi.
MADMAN-you have any pics of the OUTLAW setup? e-mail them to me.
Tom-everything is doing good with the engine. Will be trying my intake agin with a direct port setup soon has I get this fixed <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . Will have it fixed next week.
Not sure if Iam going to get a whole new setup or just make a new beefy bracket and get the T\A off the trans.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Futral Motorsports:
<strong>Jason-I was impressed how SCD was hooking. Going to be going to SCD on wednesday more often.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool, let me know when you head back out there. I haven't been to SCD in over a year.
btw, the gears and fuel pump are in. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Thanks for all the advice with the gear swap. I'll call you tomorrow and let you know all we had to do to get the crush collar crushed. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Jason
Jason
