9'' questions for the racers
Anyone happen to know the weight difference between the aluminum center sections and the nodular iron ones? And the weight difference between Moser and Strange?
As I understand it - the Moser aluminum case is stronger than the Strange, but would either be acceptable for a daily driver car that goes to the track say 2 times a month?
Also - has anyone used lightened gears? If so what kind of difference did it make? I figure the lightened set would be a little more fragile - true??
Thanks
Thanks
Re: 9'' questions for the racers
Ok - finally got the Strange catalog to load up.
Strange:
Pro series iron = 33.5 lbs
S-Seris iron = 26.7 lbs
Aluminum = 13.5 lbs <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> - but more wear on the gear set <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Moser:
Iron - 40 lbs
Aluminum - 18.8 lbs.
<small>[ April 15, 2003, 05:28 PM: Message edited by: ClassicCollector ]</small>
Strange:
Moser:
Iron - 40 lbs
