Cooling Question??
Cooling Question??
Its not showing any coolant in the resivoir but the radiator is full because it wont let me put any more coolant in. Also the coolant light came on then went off? Not overheating. Any suggestions???
Thanks....
Thanks....
When I check the reserve its empty. Hot or cold. Usually I see water on the gauge but its bone dry. If I had a leak in the reserve wouldnt I keep having to add coolant to the radiator? I figured that since the reserve fills up as you add coolant to the radiator that the radiator would be low as well. But its toped off. What would happen if I added coolant directly to the resrve bottle?
