What lugnuts for Weld Pro Stars on 2002 Z?
Are these correct for the front and rear (if different)? If not, what do I need? TIA, Shawn
1.310'' long x .687'' dia. Shank Lug Nuts: Fits Pro*Star (96 series), Part #927-601-1412 12mm x 1.50 RH Closed End Nuts w/Centered Washer 4/Pkg.
Re: What lugnuts for Weld Pro Stars on 2002 Z?
what you posted is exactly the lugs you need. you may want to go with open end though if your tech inspector checks for stud length
