All 8 of my spark plugs on my new motor are dripping in oil, any idea why?
Old 09-14-2004, 10:19 PM
verbs's Avatar
Unhappy All 8 of my spark plugs on my new motor are dripping in oil, any idea why?
Well, I'm a bit perplexed here......
I have a new forged motor/heads with only a couple thousand miles on them currently, and while swapping to a different set of heads today, my mechanic mentioned all 8 of my spark plugs came out dripping in oil.
I also have been eating oil too. I'm down two quarts on my first 3000 miles on the motor.
Being that all 8 plugs were coated, he suggested that maybe it could be bad valve seals on the heads, but also mentioned the motor/block could be bad as well (but not very likely unless the motor is overbored)
Also, I paid for comp 921 springs/retainers, etc...but on the heads there was a mix/match of retainers....and they weren't comp retainers. Also, some of the valve seats aren't even centered. Not sure what's going on...
Any suggestions/ideas?
Old 09-14-2004, 10:23 PM
cyphur's Avatar
F#ck. I'd call whoever built your motor and ask if they've ever had any issues like this. APE is a pretty good shop from what I understand. Since its within the first few k's, there should be a reasonable presumption that a material failure would be corrected. Hit them up.
felton316's Avatar
Did you make sure that you put thread sealer or loctite on the rocker arm bolts? If they are ported heads, more than likely the rocker bolt hole has gone through into the intake port, so it needs to be sealed.
Old 09-14-2004, 10:35 PM
verbs's Avatar
No that was not done.
also, just added above
Old 09-14-2004, 10:37 PM
cyphur's Avatar
Hmm interesting I did not know that.
Old 09-14-2004, 10:46 PM
6 Second Club Moderator
LASTLS1's Avatar
Mine were sealed and it was my heads. Changed heads, no more oil on plugs. BUT the rocker bolts HAVE to be sealed.
Old 09-14-2004, 10:51 PM
mean02's Avatar
Mine had oil on all the plugs and I changed the valve seals. No more oil on plugs.
I put new, factory seals in.
Old 09-14-2004, 11:34 PM
T/A Medic's Avatar
and when u go back through cut off some of the rocker are bolt so it doesnt stick down into the intake port... use some Black RTV on the bolts
Old 09-15-2004, 06:00 AM
mikemodano9c's Avatar
you put the locktite towards the top of the rocker arm bolt, under the bolt head where it sits on the rocker arm correct?
do you actually put any on the threads?
Old 09-15-2004, 06:05 AM
Scalpel's Avatar
Can the bolts actually be seen through the intake port? Just curious.
Old 09-15-2004, 08:04 AM
Senior Member
Country Boy's Avatar
I dont think the bolt is long enough to extrude into the port. I put thread sealer on the threads.
Old 09-15-2004, 09:06 AM
Bhogan909's Avatar
Verbs,
These problems you are speaking of are they the old heads or the new ones?
Old 09-15-2004, 09:45 AM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Matt,
Give us a call here, and we can help you trouble shoot.
Thanks
Old 09-15-2004, 09:56 AM
cyphur's Avatar
Originally Posted by Chris@AP-Engineering
Matt,
Thanks
Old 09-15-2004, 10:09 AM
verbs's Avatar
Originally Posted by Brian H @ TEA
Verbs,
Brian, these are the old LS6 heads that I'm pulling off and replacing with the new ones you guys just sent me.
