cruise control not working no blown fuses
cannot figure out why cruise control isnt working. no blown fuses unless there is another fuse box that i dont know about, the 2 under the hood on drivers side then in drivers door jamb. hp tuners cant do a diagnostic on that can it? let me know please. thanks.
Check your taillights. They are all on the same circuit as your cruise control.
If it's an intermittent problem, it can be a bad connection in the bulb harness. Usually it's from corrosion.
My cruise control quit working all of a sudden, I did some testing and noticed that my clutch pedal switch was defective as it never changed voltages when the pedal was depressed. I put a new switch in and it corrected the problem. Normally on a M6 if you depress the clutch the cruise control will deactivate. Also if your car is a M6 you can also adjust the depth of the switch as your switch may not be depressing all the way when you let your clutch out.
