Oil Pressure problem
Old 09-15-2004, 05:50 PM
99CamaroSS_'s Avatar
Default Oil Pressure problem
ive noticed that ever since ive done a cam install my oil pressure hasnt been as high as it used to be. i just installed headers and new TB and i have just been noticing the oil pressure lately and getting kind of worried. when i start the car its at about 40 psi but as i go and get on the road i normal stay at 20 psi at all time except for when im about about 2500 rpm and even then its about 30 psi. it jumps around a lot like that and when im stoped or coasting im at 20 psi or so. anyone know what the problem is or might be?
Old 09-15-2004, 06:00 PM
luv2spd's Avatar
Did you mess with the oil pump at all when you did your cam install? The o-ring is probably the culprit if you did.
Old 09-15-2004, 07:16 PM
pimpmaro's Avatar
Yup, you might want to get a new O-ring and install it just in case, even if your old one isn't torn.
Old 09-15-2004, 07:25 PM
Boostaholic's Avatar
I 3'rd the oring problem, it leads to a solution about 90% of the time in these "low oil pressure" threads.
