A.C. Delete has anyone.......
Has anyone deleted all of the AC crap from the engine compartment. I mean how difficult is it to remove the inside bolts and does the heat still work?
Re: A.C. Delete has anyone.......
Heat will still work, compressor, condensor, and all the lines will come out, takes about 20-25 minutes w/proper hand tools... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I think he means EVERYTHING about the a/c including the bigazz box in the compartment... that was a bitch to get out... had to break the box it was contained in .... i wouldnt recommend taking the condser out unless ur motor is out or u can get the dash moved to pull it... i didnt feel like keepin my Heater and Such, but my buddy in his LT1 did it...
but here is befor and after
Before!!!!
<img src="http://www.wckdbrd.net/byebye.jpg" alt=" - " />
After !!!!
<img src="http://www.wckdbrd.net/bay.jpg" alt=" - " />
Before!!!!
After !!!!
"The Drag Racing Director"
Removing your A/C and heater box makes a world of difference in the engine compartment. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
All kinds of room to change plugs. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
I think we saved about 43 pounds by removing everything. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Coach
Coach
Ya I would lIke to keep the heater gets a little cold here in oct. So does anyone have picks or can tell me how to keep the heater?
Tom The Roofer bought an aftermarket heater from Summit. something like that will work just fine for keeping the heat. there are plenty of aftermarket heaters you could use from electric to water fed. JC Wittney sells quite a few heaters
I've done the same, and eventually need to pick up an electric heater to put in the dash. Besides taking everything out, you need to fabricate the blockoff plate (like the one in the picture, that is well done) and blockoff the two holes in the waterpump.
