LS1 Build help
LS1 Build help
I hate to ask general questions but I want to gather all opinions before I begin to get cracking on my engine. I recently purchased a LS1 out of a Corvette 6-speed, not the Z06. The engine has 9,000 miles on it, and looks great. I own a 1999 Camaro SS with a LS1 I will be driving of course while I build this engine before I drop it in my car. Now the questions....
I live in Colorado, so I want to get a turbo, I was thinking JL because the banks twin turbo kits I do not believe work on the LS1, and Incon is impossible to find. What should I do to my engine to make any turbo last?
Also, any additional ideas for turbos would be nice. [I know this isn't the FI forum]
I was thinking of the T-rex cam and Patroit heads. What do you think? How do these respond to normal engines and what additional parts should I buy to surport a cam of this size?
What other parts should I buy while I'm at this project? LS6 oil pump, additional internals, strokers, anything you can think of or have done that you like the results of.
I do not want to spend a ton of money, but I will be going to be able to spend a fair amount. Please I would like more then one opinion. I apologize again how general this question is.
Also. I would like this to be a daily driver, or weekend warrior but nothing strickly track, gas mileage is not a factor though.
SN95 Director
First and foremost, make sure you have the fuel system to support it.
A good set of rods and pistons will go along way, stick w/ the stock crank. I ain't broken one yet, but I'm sure as hell trying.
You don't need super bad *** heads, unless you're going full out. A nice set of stage one heads will work in most cases.
As for cam, something in the mid 200 duration, probably mid 500 to 600 lift. Call Futral, they can get you a nice turbo cam
Could go bigger, but all depends on how much power your after.
How far up the mountain are you? You'll be able to make up for the altitude w/ the turbo, but watch the cooling. Thin air just can't reject the heat as well.
Got any HP goals/targets?
As for a turbo system, at this point a single is the most available in kit form.
That motor is too good to mess up,get a 6.0 iron block as you can bore it up to .030 use stock crank(its a little stronger then ls1)get forged rods and pistons and turbo rings.The 317 truck heads flow well and have bigger chambers to lower CR.Just do a clean-up on the ports as well as good valves and valve job.Get a turbo specific cam!!!!!!Get strong valve springs and strong pushrods as the boost puts a load on these parts.Get your heads before you get your pistons as this will determine how much cc dish you need to get the proper CR.ARP head studs and good head gaskets are a must.Check the post in the FI section as there is a lot of good info for your build-up.
