2.02 valve vs 2.05 on a stock bore
Which flows better? I just had my heads ported out to stage two and the head porter said the 2.02 are the way to go with a stock bore as there is really not enough room for the 2.05 and they are too close to the gasket which effects the quenching of the combustion chambers? This is on a stock bore. Should I have made him install the 2.05's? My heads now flow 306 cfm at .650 and 300 at .600 which is pretty good.
Back a year and a half ago when I had my heads done, everyone told me I had to go with 2.02s.
Recently, a month ago, I had my heads redone. I went with 2.08 valves this time and picked up power from before.
we use 2.055 in our new 2.5 5.3 heads we've been consistantly seeing numbers in the 320s at .600 with good low to mid numbers aswell that tells me a 2.055 is not too big for a 3.9 bore
Originally Posted by goober35
He could have forged pistons. The they are vavle reliefs and not flycut. I think
Lunati pistons that came with valve reliefs
Collections Hold
Originally Posted by Dustin 98TA
I have the 2.055 with the stock seats, no problems whatsoever.
Is there really any reason, to go over stock size? Proof, I mean? Or is this just part of that bigger is better mantality that this site has?
Just curious, thats all. Guessing valve diameter choice has to do with the setup.
1 Post
Engine requirements
Physical block restrictions
Chamber design
Port design
HP requirements
Still in all, you are on to something.
It's really a balancing act between what works and what is "supposed" to work...
Ed
