Couple of cam comparisions for your viewing pleasure
I have been looking at cams that give similar valve events as my 236/242 110LSA 110ICL cam but are more emissions friendly (less overlap) and will have excellent idle manners
Here is what I have come up with so far. Which is your favorite? I prefer to add a little exhaust duration as there are cats on the car.
I dont think the added exhaust duration will drastically affect whether or not the car passes emissions...
Thoughts appreciated!! My current cam peaks at 6000rpm and carries power well to 6700rpm.
Cams from left to right:
236/242 110/110
226/232 115/115
224/230 116/116
220/226 118LSA/118ICL
IVO 8 -2 -4 -8
IVC 48 48 48 48
EVO 51 51 51 51
EVC 11 1 -1 -5
ECL 110 115 115 118
OL 19 -1 -5 -13
Thanks to Jrod for the cam spreadsheet, saves so much time!!
236/242 110/110
226/232 115/115
224/230 116/116
IVO 8 -2 -4 -8
IVC 48 48 48 48
EVO 51 51 51 51
EVC 11 1 -1 -5
ECL 110 115 115 118
OL 19 -1 -5 -13
That's a ton of overlap that you are giving up. Overlap has a direct bearing on passing emissions, but giving up that much overlap is bound to cost you some power somewhere. I guess the question is where do you want to cut power? I agree that with cats that a little extra exhaust duration might make sense.
Of your choices, cam 1 would be my choice, but I think the LSA is too high. Put it on a 113 LSA. A 228/232 114 114 would be very mild and should be on your list. I would not consider the 118 LSA cam.
I just found it very interesting that a 16 degree duration difference can still yield similar IVC and EVO valve events
LS1 Tech Administrator
The 115 cam is right on. It would rock on your larger cube motor and make peak power at exactly the same rpm as your current cam (because of the same intake closing point). I like an intake closing point of 44 degrees for a 346 so 48 degrees should be ideal for a streetable, but kickass 385! Good job!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by JS
Opps I meant the cam Patrick mentioned. (Cam #2)
The added dur and the 115 LSA should idle well and make great power in your 385....
I assume you think these IVC and EVO are the values, but I dont think you are giving enough importance to overlap or duration. Valve events are very important, but if there isnt time to fill or evacuate the combustion it still wont perform like it should. Even on your most aggressive alternative you are giving up 20 degrees of overlap at .050. I think option#4 is way too small and you are giving up way too much overlap just to idle better. I would definitely cross that off your list as that is a mild 346 cam. Option #3 is better than 4, but it still gives up too much duration for the bigger motor to make good power. I was looking at a 224/230 115 for a 346 blower emissions cam which means its probably not enough for a 385. Option 2 is the best of your alternatives if you are set at staying under 0 degress of overlap.
My preference is 226/232 115/115 as well.
This is more of a post to generate discussion and to show that smaller duration can behave like larger duration (to a certain extent)
I havent gotten into the duration differences at different lifts with the various XE-R lobes
Thanks for the comments keep them coming!
cam events is the IVC event, around 71...73 deg ABDC. Is your 44 degress
at .050 lift of .004 lift?
Gert
Originally Posted by 2000SSNB
In some of the cam reference articles I read that the the largestimpact on
Gert
Gert
__________________
It went from explosive torque at 2k and up, spinning the tires from idle, to much smoother stock zo6 like accelleration on up to around 6500.
My MMS 220* is a SBC Magnum lobes ground on a LS1 blank, this "grows" the specs to 276*@.006" 226*@.050" and .585" My Ivc is at 46*ABDC with ICL at 114*. I havent ran car at track to test this adjustment but my plan is to run fasteron street tires by moving torque peak up. My point for posting is I feel that the motor is very sensitive to this change and assuming a 115*LSA and a late IVC point is a general ball park move, would be a mistake. I didnt change cam size and yet car feels completely different and has required several Edit tunes, for "Big Cam" DTC's and driveability issues.
Originally Posted by LS1derfull
I can attest to small changes in IVC making a noticeable change in torque characteristics. I retarded my 220*/220* on a 112*lsa from 110*ICL to 114*
My goal is to smooth the idle out for emissions/drivability reasons while keeping valve timing events similar to maintain the rpm peak horsepower occurs and to try and keep the power level between the two cams relatively close to each other (within 5RWHP of each other)
As long as the car makes similar horsepower from 4000-6500rpm I'll be happy.
The car completely overpowers street tires now even in third gear. I'll sacrifice a little torque to improve drivability and emissions testing.
I think the power differences between the two cams will be quite marginal but the drivability will be much improved.
I will definitely be retuning the car after the change. (if I indeed swap cams)
running closed loop but looking at open loop solutions as the car has a hesitation at part throttle that drives me banannas sometimes
open loop and cats dont get along though, that is part of the reason I was looking at a friendlier cam
If you think that you can drastically cut your duration and overlap, and significantly increase your LSA and make within 5 HP, then either your first cam sucked ***, or you have discovered a magic formula that you need to patent. Maybe you'll prove me wrong, but you are making a radical change here.
The reduction in overlap/duration with wider LSA will hurt absolute peak power numbers somewhat but will actually help power past peak. (the powerband will be less peaky and not fall off as much.
The duration numbers at .200 and up from lobe differences will have an effect but I dont think it'll be too severe.
I am guessing 5-8RWHP difference tops if that.
