torque converter for trex?
Old 09-18-2004, 01:48 AM
Retired Street Racer
Matt D's Avatar
Default torque converter for trex?
i am going to go with the v2 trex cam, and was looking at the tci 4400 stall...would this be a good setup, or should i choose a different stall...it is not a daily driver, and going to be running on 255/50/16 mickey thompson drag radials...thanks
Old 09-18-2004, 02:40 AM
2MuchRiceMakesMeSick's Avatar
Depends, Do you plan on spraying the car? That would be a good setup for all motor
Old 09-18-2004, 03:32 AM
badexpl_00's Avatar
If i where you i would have to go with a yank 4400.
Old 09-18-2004, 05:18 AM
samz28's Avatar
i dont think the TREX is too spray friendly lol. and i'll be the first to tell you those drag radials will be useless. My tiny cam destroys the nitto's on the tiny 3500 stall.
ET streets or slicks man. Dont waste your time with nitto's unless you just want to smoke some tire on the streets and rack up some poinst with the man
Old 09-18-2004, 12:52 PM
Matt D's Avatar
no, i don't plan on spraying it, and want to keep the stock heads. i am not going to run nitto dr, i am going with the mickey thompson drag radials...they hook a lot better.
Old 09-18-2004, 02:17 PM
Mooobunnny's Avatar
especially with 2.73 gears.....my car hooked really well with 2.73's......switched to 3.73's and now I spin a lot (on sllicks) and have not matched my previous 60ft time yet....
Old 09-18-2004, 07:00 PM
DEEZ98Z's Avatar
I would say a PT 4000 or PT 4400
Old 09-20-2004, 12:57 PM
Matt D's Avatar
anyone else?...i am going to eventually switch to 3.73 gears and a 26in et drag
Old 09-20-2004, 07:56 PM
CamaroCain's Avatar
3.73 gears, a good tire like that and a Yank PT4400 should do you just right
