HP Tuner and A/F Ratio
Hi,
I am getting HP tuner and was looking for some tuning help to get me started. I was on a dyno last week and my A/F ratio at WOT was 11.5 on average. To correct this to around 13.0 would I X each VE table by 95 or should I just do some tables. On the dyno graph at wot it goes to 12.0 at 3000 rpm and gradually goes down, then at 4500 it drops again and at 6000 is at 11.4-11.6. I installed 28.8 fuel injectors in my 99 which originally came from the factory with the 26.?, would this need any adjustments.
Thanks for any help, Chris
Originally Posted by slow
setup your injector tables for the 28.8 info, and that should help not correct the problem.
Ryan
Ryan
Originally Posted by cbota
Hi,
I have got my HPtuner and need some help with tunining. I have my bin file and need to know with tables to change for the 28.8 injectors that replaced the stock 26. I also did a scan and it seems the values are all over the place, any help would be appreciated. Thanks
LS1TECH Sponsor
Hi,
