Fierce-LS1
09-18-2004, 11:56 PM
Anyone know how to delete the reverse lockout signal from the PCM ?
HumpinSS
09-19-2004, 12:07 AM
why would you want to do that
Fierce-LS1
09-19-2004, 12:26 AM
4l60E was converted to T56. Have no clue where to tap into the PCM for the reverse lockout and I'm tired of looking at this damn SES light :cry:
horist
09-19-2004, 03:08 AM
http://www.ls2.com/boggs/torques/00pinpcm.htm
pin 44 on RED connector seems to be it... I believe the connections for 99-02 F-Bodies are the same... maybe someone has an 02 pinout to verify though?
wait4me
09-19-2004, 08:17 AM
you could just disable the code, in the dtc section? it says pin 44 on the computer is for reverse lock out, just go get a connecter from gm for 13 dollars, then run one end of the wire to a 12 volt ignition wire, then the other to pin 44, you will have to just move a wire to that spot, you can use any from that 4l60e harness you are not using anymore,
waucanda, i picked up my tranny from there, a place called hpa ? i got sooo lost trying to find that town... i thought it was right in chicago, then ended up i dont even know where... some nice cars in there though, even the only mustang i would ever drive, :) that ls1 f1 blower mustang.. ;)
ataylors
09-19-2004, 10:37 AM
I wish I could change when it engages.. I hat not being able to go to reverse on a slow roll..
Fierce-LS1
09-19-2004, 11:11 AM
thanks for the help guys :cool:
