What do i need for pulleys?
Im going to be getting an Asp pulley very soon and I did a search and im still confused about what i need. i have no aftermarket stereo system or subs that require a lot of power. What should i get? Do I need the crank and alternator pulleys or just a crank pulley? Im a newb so I have no idea what to get.
1 Post
www.thunderracing.com
You're going to need:
ASP Pulley
Shorter Accessories Belt
Shorter A/C Belt
The Thunder site breaks it down for ya.
ASP Pulley
Shorter A/C Belt
Ok so i need
- Belt for AC Pulley, 1998-2002 LS1 F-body
-ASP Harmonic Balancer Crank Pulley, SFI 18.1 Approved, 1998-2002 LS1 F-body
-Accessory Belt for ASP Crank & ASP Underdrive Alternator Pulleys
is that right?
is that right?
1 Post
Originally Posted by 01sunsetSS
Ok so i need
is that right?
is that right?
Belt for A/C
Accessory belt for ASP Crank pulley only.. (since you're not buying the alternator pulley)
Ok so i need
is that right?
is that right?
