PVC on milled LS1 head
I am hoping to jump CR to about 11.75:1 Am I going to have enough PVC to mill the head to achieve that ratio with the specs on my below cam. I am also going to keep 1.7 rockers. If that sounds like too much. What would be a safe tolerance I could mill the head to still be ok on space.
Thanks
Brandon
Thanks
Brandon
IMO with that cam you'll need fly cutting.
But first what heads? LS1's?
Because with an LS1 you'll need 57.39CC for 11.75:1 and even with stock valves you'll flycut.
Probably ~ 10.5 CR would be your max (estimate)
Thanks
Brandon
