LS1BirdDRG
09-20-2004, 04:46 PM
Well, my fears were confirmed yesterday when I removed the tranny and clutch and found no "visible" signs of a clutch failure. The clutch disk seemed ok and wasn't worn down to the rivets like i thought. The pressure plate didn't show any signs of failure either. While I'm no expert, I must point my finger at the tranny right?
Ok, here's what happened: On a WOT shift to 3rd, it sounded like I missed a gear but felt like I broke the tranny. I went to 4th and everything seemed ok I just cruised in 4th until I got close to home. Then come to find out I still had 3rd, and the clutch engagement felt normal. I had all my gears and everything was normal UNTIL I gave it more gas than say 1/4 throttle. Then it would make a slipping grinding sound and act asif it was in neutral. With normal nursing the car driving it makes no noises and appears fine.
I drained the fluid in the tranny and found no metal. Is there any way I can test the tranny out of the car? Thanks in advance for any advice!
Btw, it was an origional stock clutch that was starting to slip alittle on lauches before the catastrophe. :eyes: 30k miles
