Whats The Highest Youve Spun Your TREX To??
Who in here has spun their trex the highest. I have taken mine up to 6400 but im still on a stock bottom end. Is there anyone that goes higher then this?
Well its my daily driver, I plan on a forged 408 soon. Im just wondering when the trex quits pulling. I remember a graph going up to 7200 with a trex but I cant seem to find it.
Originally Posted by 93LS1RX7
Hell I have a stock short block and shift mine on the street at 7k.
You have stock internals, spray it reving to 7k, gooood lord man
408+Trex= one bad motha! I can spin this cam all the way to 7100 rpm with no problems on my a4. It just keeps pulling on the top end. i was very pleased, since I went from a stock ls1 on the juice, to a 408 iron block (with trex cam) with nitrous. Good luck with the setup and keep us up dated!
Mine will hit the 7400 RPM limiter pretty fast! I shift around 7100 normally, but I swear it still feels like it's pulling hard past that. Your only just starting to use the potential of this cam when it reaches 5500 RPM and above...
Dan
Dan
i've seen 1 guy at the track rev it to 8000k on a forged 382 all bore. i sat in the car during his last 1/8 mile run and couldn't believe my eyes as he burried the stock tach then the shift light came on a few milliseconds later
I dont spray it at 7k are you crazy, the juice cuts at 6800 haha, if it blows just a better reason to upgrade and go with a forged stroker!!
Stock pistons etc. I have upgraded rods, springs, timing chain and oil pump but the rest is stock.
Hhaha well if it cuts out at 6800 thats ok As for the stroker, I heard that, Ill use it for an excuse to buy a 408
I am puting the motor in the car now with T-REX in a 427 alum, block stroker, whay do you think I should set the shift light at? and what do you think that cam will be like in the stroker/
Why the hell am I only peaking at 6500 with the rex?! I took it to 7200, the power has already died. i made 424sae wheels through a 12 bolt. but the peak wasnt high like i always hear about and see.
DAAAMMMM........what do I think it would be like....REDICULOUS ill find out after I get all my body/drive triain/suspension built up for it.
