Locking Torque Convertor
I've got a 93 TA with a 700R4 tranny. I'm trying to get decent numbers on the dyno and good datalogs. I cant seem to keep the torque convertor locked up. I bring the rpm's up in 3rd and let the convertor lock up. By the way it is a 3600 stall. I bring the rpm up to about 3000 so it wont downshift and let er rip. It unlocks the convertor everytime. Am i doing something wrong? How do people keep there convertors locked during dyno pulls?
Programming is one way. Rigging up a switch inline with the TCC harness is another. You have to know which pin to ground.
The converter should never lockup at WOT unless you program it to. It is not programmed to do this from the factory.
BTW, the above info is what I know about 4L60-Es. I can't vouch for 700R4s but I would assume that they operate similarly in this regard.
ok....thanks for the info guys
Are most people with automatics locking there convertors by this means one the dyno? or are they just running them unlocked and letting them slip?
