polishing parts
polishing parts
what parts on my ss can be polished is it just the aluminum parts or can other metal parts be polished also which parts are aluminum
Anything metal can be polished. Some of the harder metals just require a little more elbow grease! Everything metal under the hood can be polished to a brilliant luster. Good luck.
You should pm that one guy with the black Camaro w/ polished everything underhood and under chassis. He's got chrome zr-1s and is procharged in his sig. Does anyone know who I'm talking about?
Tech Addict
Mustang5.Ohater...Thanks.
Here is a write up I did that should help....
How to Polish
Metal parts are hard to polish and they will rust if not clear coated.
Here are some parts I just polished that are metal...
After...(I did not detail the washers, they will not be seen) These are the sway bar brackets ect..
Before...
How to Polish
michelinss what parts on my ss can be polished is it just the aluminum parts or can other metal parts be polished also which parts are aluminum
Before...
i guess this question will fit with this topic, would i be able to use like polishing compound (the stuff found down the ''car care'' isle at any store) with the polishing attachments on a dremel to polish metal and such, or do i need to get the polish that dremel sells, or is there something else i can get?
Tech Addict
Originally Posted by Todd2001SS
Some polishing compound is really metal cleaner. Make sure you use White Rouge & Tripoli. The surface contact area on a dremmel will make it hard to polish larger parts also the wheels get dirty and you have to throw them away very often.
