#317 Vs.#035 Heads - Whats the difference?
Old 09-21-2004, 07:12 AM
Billiumss's Avatar
Question #317 Vs.#035 Heads - Whats the difference?
What is the main difference between these two types of heads?
- They both have the same size combustion chamber.
- They both had the "D'" shape exhaust ports.
- They are both made out of aluminum.
From the way it looks, after you get them ported, shouldn't they flow the same?
Old 09-21-2004, 08:11 AM
2000Firehawk's Avatar
One is a better casting.
317 = Sand casting vs 035 = diecast.
Can't remember which is better.
Patriot did buy 100s of the 035 diecast, so I would think that
it would be the better of the two.
Dave
Old 09-21-2004, 10:25 AM
marc_w's Avatar
I would think diecast is better...?
Old 09-21-2004, 04:29 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Originally Posted by 2000Firehawk
Patriot did buy 100s of the 035 diecast, so I would think that it would be the better of the two.
Keep in mind that there are several shops that are fixing 100s of Patriot 035 diecast heads.
Old 09-21-2004, 04:45 PM
MeanWS6's Avatar
part number: 12572035
I found two casting numbers, casting number should be either 317 or 035 (02 and up LQ9 6.0 aluminum heads)
Specs:
LQ9
01+ 6.0L Truck
Material: Aluminum
Combustion Chamber Volume: 71.06cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Maybe Shaun @ SMC can chime in (or someone bump him this post). I heard he has these heads at a good price.
ValveGod@aol.com
Old 09-21-2004, 07:43 PM
Billiumss's Avatar
What type of castings are the #241 & #243 heads?
Old 09-21-2004, 07:56 PM
johnny p's Avatar
# 241 = LS1 /01 & up ---------- #243 = LS6 01/04 Also try this Link
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Old 09-22-2004, 03:27 PM
Billiumss's Avatar
I know that, but what "type" of castings are they, sand or die?
Old 09-22-2004, 03:49 PM
TVWilkes's Avatar
The 241 & 243 castings are diecast.
Old 09-22-2004, 06:02 PM
FlyinGTP's Avatar
Just an fyi, any fbody built after 1/00 had 241 heads. i found this out with my trans am and a couple other 00 fbody's. If its a 00 model year car built in the last few months of 99 it will not have 241 heads.
Quick Reply: #317 Vs.#035 Heads - Whats the difference?
