How can I find out what posi unit my stock rear end has?
Old 09-21-2004, 11:26 AM
9 Second Club NA
Dragaholic's Avatar
Default How can I find out what posi unit my stock rear end has?
I have a 2000 Camaro SS. It was originally a 6 speed car, so it came with a 3.42. Just wanted to know what kind of posi/limited slip unit I had. Thanks.
Old 09-24-2004, 04:28 PM
LSUZ28's Avatar
I believe you have the zexel torsen unit. I uses gears instead of the older style that use clutch discs.
Old 09-24-2004, 06:18 PM
9 Second Club NA
Dragaholic's Avatar
How can I tell though? Im sure there is a way, just need to know. I want to be 100% certain so that I can include it in my for sale description. Thanks.
Old 09-24-2004, 09:06 PM
Moderator
jimmyblue's Avatar
Both wheels in the air, trans in neutral, the OEM Torsen
will counter-rotate if you turn one wheel (same as an
open diff) while a clutch-type unit (assuming the clutches
aren't completely shot) will have both wheels turning
together.
Old 09-24-2004, 10:03 PM
LSUZ28's Avatar
together.
That's the easiest way I know.
Old 09-24-2004, 11:35 PM
9 Second Club NA
Dragaholic's Avatar
The rear end isnt in the car anymore, but I spun one axle while it was on the ground and both axles spun the same direction. So if its the clutch type, whats its name/brand?
Old 09-25-2004, 07:56 AM
LSUZ28's Avatar
I think that only the 98's came with the posi. 99-02 came with the torsen, but the posi was a special order option from SLP. I believe it's Auburn that makes them.
Old 09-25-2004, 01:58 PM
9 Second Club NA
Dragaholic's Avatar
Well I dont really know what to think...if I spin my rear and both of them turn in the same direction, its an Auburn, but the rear came out of my 2000 SS and only 98's came with Auburns. Im so lost, is there any other way to find out what I have?
Old 09-25-2004, 04:52 PM
Moderator
jimmyblue's Avatar
You could pull the cover and inspect it, vs the pics on
manufacturer's web site. Might find a number on the
carrier. Zexel has a bunch of helical gears in it. You
might have received the "special order" rear end as
SLP had a lot of leeway in what they put onto non-
pre-ordered vehicles.
Old 09-25-2004, 07:56 PM
LSUZ28's Avatar
If you have the original paper work that came with the car, you may be able to find out from there. It sounds to me like you have the Auburn Posi.
Old 10-04-2004, 10:15 AM
TATER's Avatar
I have a 1998 with the Auburn Posi. Weak as ****. Drag radials and stock power = new spider gears, but I hear Auburns are unserviceable, so... you're screwed? I dunno, but I hate my 10 bolt.
Old 10-04-2004, 07:47 PM
Peabody Holdaway's Avatar
What type limited slip does the '99 Trans Am LS1 have? Is it the Zexel? What weight rearend grease would you recommend running in this? I am having the pinion bearings replaced and contemplating synthetic grease. Also, do you have to put in a bottle of limited slip additive????
Thanks,
Peabody Holdaway
Old 10-04-2004, 08:44 PM
Moderator
jimmyblue's Avatar
You should confirm what kind you have as lube needs
differ. Presuming you have the later stock Zexel...
Don't believe you need any additive in a Torsen. I've
read that using heavier weight gear oil (not grease)
will increase the torque biasing limit on the stock unit
which is a good thing. I went thicker but didn't notice
much out of it. Word to the wise, change the rear oil
often, it's recommended at like 10K intervals but it
seems not to have been part of my regular dealership
maintenance, gear-to-case Torsen bind process seems
to make shavings as a regular way of business. I think
this is only when you actually get into wheel slip under
power (but who would do a thing like that?). Anyway,
it wants changing more often than it usually gets.
Old 10-06-2004, 01:56 AM
RoadHazard's Avatar
The Camaro SS from 99+ should come with Torsen diff from factory. However, there's an option from SLP to upgrade to Auburn Pro which costs extra. You may have one of those cars. As far as I understand, if you see spider gears and springs in the POSI, that's auburn. But if you see only a bunch of helical gears, that's Torsen.
Quick Reply: How can I find out what posi unit my stock rear end has?
