MTI 5.3 Stg IIe and G1 cam on a C5/6spd
Looking for advice/recommendations/experience with MTI 5.3 Stg IIe heads and their G1 cam. Things like RWTQ, idle, quality. I have a 2001 C5/6spd with a Vararam and LG-Pros...
Any help would be appreciated....
How about just heads...
I heard that a 01 Z06 with bolt ons and stock heads pulled a 415rwhp. The graphed looked "nice." So you figure with the extra compression and better flowing heads you'd get more than that I'm going to guess 430-435. If you get it on a 114 it will drive like stock with programming on a 112 it will be fine as well but alot more lope at idle.
Hope that helps. Its the cam I'm going to go with, with stock LS6 heads.
I will make this short MTI ROCKS.
Give David or Wayne a call.
I have yet to see any MTI H/C car make less than 420 rwhp.
Jayson is bar none the Master of LS1'S.
I have seen alot of shops come an go, MTI just keeps growing.
Mine is a A4 and she runs sweet! I`m safely tuned and pulled 414rwhp with 12-bolt and all! Jayson and crew rock!! Go with thwe 112 lobe, the sound is sweet. Just get it tuned!!
I have MTI LS1 Stage 2E heads, MTI C2 cam with underdrive pulley, Kooks LT's with x-pipe and hi-flow cats,and blackwing intake. All installed and conservatively street tuned at MTI. 417rwhp and 395 trq on a 90 degree day. See dyno chart below. The G1 is a more powerful cam by about 10-15hp.
It was your sound file that actually got me looking at MTI. I had already made my mind to do the AFRs and their 224/228 cam but decided to research one more option. If I can get them to spread the lsa to 114 or 115, on the G1, I will probably go that way... I have Corsa Touring mufflers so I am hoping they will tone down the idle to something I can live with...
Thanks for post...
MTI can get the LSA you want. One of the locals got the G1 for his procharged vette and got a 114-115 lsa so it would work well with the SC.
If you are not supercharged I would stick to the 12lsa. Better under the curve power for the street and moree lope for that cool sound.
Good info... Actually I am a little older than most here and my lopey idle days are behind me. I talked with Wayne at MTI and he said I could get 114-115 on the lsa and have 4 degrees advance ground into it to bring the power curve back down the rpm range. Hopefully my Corsa Touring mufflers and a high idle (900rpm) will smooth out the the idle....
Thanks again...
That sounds like the ticket to me. BTW I'm 48.
Man its nice to know there are some older guys that love these cars. I`m 36 going to be 37 soon. I have a few friends that just don`t understand my passion for a LS1, or the money I spend!! By the way, you can see in Sig I went with the X1 on 112 lobe and love it. Jayson at MTI tuned her and she runs awsome.The sound is badass!!! I`m safely tuned for the spray and love it!! And with A4 and 12-bolt!
Originally Posted by SSideExhLS1
whatever you do, you cant go wrong with MTI!
Thanks for all the replies.... even those from the old farts...
Now if I can just get LG to ship my headers!!!
