Another question on a Predator
How is shift points and shift firmness adjusted with the Predator? Is either on or off or does it have ways of manually adjusting firmness and shift points. I notice the Vinci has an automatic 300rpm increase for shift point and that's it. Is the Predator the same way? How bout on the firmness. Can you adjust how much firmness or is it either on or off?
Thanks,
Peabody Holdaway
Thanks,
Peabody Holdaway
Moderator
Shift points (WOT only) are numeric, scroll to value.
Same for rev limiter.
Firmness is done by shift time and shift pressure
"+/-%" over a "25%" range. But -25% on time takes
the shift adaptation time table to zeroes. So it's more
an eye candy than a factual basis. But it works.
