AFR Heads/Cam Combo Installation/Tune Deal
Old 09-22-2004, 04:31 PM
TTPMatt's Avatar
Default AFR Heads/Cam Combo Installation/Tune Deal
We have one set of AFR 205cc in stock and numerous more incoming. We will be running a special on this heads/cam combo:
AFR 205cc CNC Heads with Dual Springs, Titanium Retainers
TTP Equalizer V.2 Camshaft
TTP Hardened Chromoly Pushrods
GM Steel Headgaskets
GM Headbolt Kit
GM Misc. Gaskets
Synthetic Oil Change w/ Filter
Dexcool
Rollmaster Double Roller Timing Chain
LS6 Oil Pump
Installation
LS1 Edit Custom Tune
Before Work Dyno Pulls
$4200
Add ASP UD Pulley with belts $240
Add Meziere Electric Water Pump Installed with Relay $575
Add LSX 90mm Intake with Throttle Body $1300
As a reference, the TTP Equalizer Camshaft series makes consistent power between 412-420rwhp on a stock ls1 head car, with stock waterpump and ASP UD pulley. The best numbers we have seen was 447rwhp/414rwtq through a Moser 12-bolt with 4.11's, stock ls6 heads, lsx 90mm intake, fast 90mm throttle body, kooks 1 3/4 lts.
If you have any questions give us a call at 973-340-4069. This is a one-time special only, all parts are in stock ready to go.
