How to add VSS to th350?
Ive never had a VSS hooked up to my LS1/th350 setup. Ive been told it can install into my th350 and be calibrated with ls1edit.
Can anyone explain what part i need for it?
My painless wiring kit has a plug in for the VSS.
11 Second Truck Club
I think I have one somewhere that has about a 1 inch long cable that screws onto the 350 tranny where the speedo cable goes then it has the 2 wires coming off of it. I am not sure what brand it is, I can look when I go to my shop.
Not that I could find for the Th350, unless you got a BOP TH350 then there are some shelf parts that will work but that is over my head.
Dakota Dig stuff is easy to put in and hook up. Ign wire, 2 grounds and 2 more wires.
If you have LS1-Edit or (better yet) HPTuners you can change the input signal reference to match. All you would need is a VSS from a 91-92 3rd gen f-body, they used an electric speedo. This might work out for you.
