Dyno in 3rd Gear?
Old 09-25-2004, 10:09 PM
pacmantravis's Avatar
Default Dyno in 3rd Gear?
There is a shop by my house that is doing 3 dyno pulls w/AFR for $35
Question is, since I have a top speed limiter set at around 115mph how much of a difference horsepower-wise would it be if I dyno'd my car in 3rd gear instead of 4th gear?
TIA
Old 09-26-2004, 11:20 AM
anybody?
Old 09-26-2004, 01:28 PM
NW Iowa WS6's Avatar
My friends 01 Z06 with cat-back only picked up 25 RW trying 3rd then going to 4th. 3rd he got around 325.? then did a 4th gear and got 351.7 hope that helps.
Old 09-27-2004, 08:56 AM
dynocar's Avatar
On load bearing chassis dynos, such as Mustang, SuperFlo, DynaPac etc, there is not much difference between 3rd or 4th. On enertia dynos, such as DynoJet there is quite a difference and varys from car to car, same with changing rear end ratios or tire diameters.
EJ
Old 09-27-2004, 11:53 AM
https://ls1tech.com/forums/dynamometer-results-comparisons/220508-dyno-d-my-car-first-time-98-z28.html
I posted my numbers on this thread.
Seem a bit low to me. Dyno was done on a dynojet.
Old 09-27-2004, 01:29 PM
xfactor_pitbulls's Avatar
You getting it tuned at the same time? If so, just have them turn the to speed limiter off. Be done with it.
Brandon
Old 09-27-2004, 01:38 PM
There was no tune done. Just pulls.
