HELP with custom axles PLEASE
I am putting together my order for my axles and need some help with one of the measurements. I need to know the "Brake Stand Out", I had my rear narrowed and should have measured it before I shortened the housing Anyone that has a F-Body rear laying around I would be eternally gratefull for your help with this
2 inches on each side. I have a 28x11.50 Hoosier on the back now with 15x8.5 convo pros 5" backspacing. I am about to get some 10's with 5" of rear spacing and roll the fender lip so it will fit.
Had to massage the inner fender with a BFH. Still needs a little more with an Air Hammer. It scrubs a bit In a slow turn.
There are pics in this thread if you are interested
https://ls1tech.com/forums/wheels-tires/203384-pics-my-convo-n-hoosier-combo.html
Brad
Brad
BTW what backing plates are you going to run? I have the stockers but if you have an aftermarket brake setup you may want to measure the thickness of your backing plate and subtract it from the measurment I gave you.
In that diagram it shows the measurement from the outside edge of the backing plate/bearing retainer. I gave you the measurement to the outside edge of the bearing.
Brad
Brad
