Is this bad? Cam with slight surface rust
Old 09-27-2004, 04:15 PM
GTS346's Avatar
Default Is this bad? Cam with slight surface rust
I stupidly cleaned my LS6 cam and left it un oiled for 2 weeks.
It developed slightest of surface rust ona few lobes and cam journal.
You can just feel the odd bit of surface rust.
Is there anything I can use to clean it up or should I just junk the cam?
Old 09-27-2004, 05:06 PM
kenkaru's Avatar
I think would see how much comes off with 1500 grit paper. The lifters are rollers so... I'm no expert though. Here's a TTT.
Old 09-27-2004, 05:21 PM
technical's Avatar
Try some penatrating oil and a rag.
Old 09-27-2004, 05:41 PM
Ryan02SS's Avatar
Steel Wool @ penetrating oil will make it look new again.
Old 09-27-2004, 07:10 PM
RoyO's Avatar
I used steel wool and penetrating on on my cam and it was good as new.
Old 09-27-2004, 08:32 PM
BriancWS6's Avatar
Soak it in WD-40 or other penetrating lubricant and let it sit for a while, then wipe it with a rag.
Quick Reply: Is this bad? Cam with slight surface rust
