TPS Voltage at Idle
Old 09-27-2004, 05:18 PM
Pro Mouse's Avatar
Default TPS Voltage at Idle
I have .37 Volts at Idle and 4.61 volts at WOT.Now my question is is the .37 volts at idle ok or is it hurting me?I did a search and had no luck....Thank you
Old 09-27-2004, 05:45 PM
horist's Avatar
TPS will never be 0 volts at idle ... at least not that I've ever seen on any car... (well any car that's running) .. .37 sounds normal
Old 09-27-2004, 05:56 PM
Pro Mouse's Avatar
No Horist I know...I was told the closer to .5 volts at Idle the better.Is this for performance reasons?
