LEd part#s
Copy & Paste Moderator
Various manufacturers pruduce LED replacements. The PN of the LED unit doesnt matter. What matters is the PN of the bulb that its a replacement for. Example, a LED assemble that is intended to replace a #3157 bulb. Althogh the PN of the LED replacement is usually the same as the original bulb.
BTW,
LEDs are not bulbs.
L = Light
E = Emitting
D = Diode
There are various manufacturers but this is the only one I can think of right now: http://www.jamstrait.com/
From what I have head, the APC ones are not good.
Do a search on here and you'll find more info and manufacturers.
Here is JamStrait's 3157 equivalent:
http://www.jamstrait.com/3157s.htm
So to answer your question, you need to find out the PNs of the bulbs you want to replace. What bulbs do you want to replace?
BTW,
LEDs are not bulbs.
L = Light
E = Emitting
D = Diode
I'm guessing you have a Camaro. Unfortunately I dont know the PNs (I have a Firebird).
EDIT:
I did some searching and it looks like 3157 is the front turn signal bulb.
Here is the list from Sylvania:
http://www.sylvania.com/ConsumerProd...de/default.htm
(Sylvania makes bulbs not LEDs, but I thought the PN List would be helpful.)
EDIT:
