Conversions & Hybrids - Custom alternator bracket
55LS1
09-29-2004, 05:06 PM
Do any of you guys know of a vendor making an alternator bracket that mounts it low on the driver or pass side, with a electric w/p and no other accessories?? I have the race pump, so I can't use the w/p as a pulley. Thanks for any info.
55LS1
10-05-2004, 03:09 AM
anyone???
John B
10-05-2004, 01:18 PM
Sorry, haven't seen one. Will a high mount work?
55LS1
10-05-2004, 11:32 PM
no, I really want to mount it down low to keep things sanitary. I might end up fabricating something, but it would be nice to just bolt something on. hmmm..
GTS346
10-07-2004, 04:31 AM
Whats wrong with the factory low mount spot on driver side?
Do you want it even lower then that again?
5.3 racer
10-07-2004, 05:56 AM
maybe you could use the factory a/c bracket for something... as it uses only the crank.
55LS1
10-09-2004, 02:48 AM
The factory low mount has no provision for putting tension on the belt. I am probably going to make something, I have't been able to find anything "pre-made" that will work. Its kind of weird, I'm sure quite a few people are running the race version electric water pump, I wonder what they are using for brackets?
Muffracing
01-15-2005, 11:26 PM
Can you use the brackets from a truck engine?
SERPENT99
01-17-2005, 01:20 PM
check my sig
badjuju342
01-17-2005, 01:45 PM
Try Street & Performance
Tom the roofer
01-17-2005, 07:52 PM
I made the stock tensioner pully work for me. Takes about 1/2 hour, grinding wheel and a 37" belt I believe. The pic is on my web site . Good luck
SERPENT99
01-17-2005, 09:25 PM
pretty cool. I thought about using the tensioner but I figured less stuff spinning around on the front of the motor would be better, I got a shorter belt and more belt wrap out of the deal too. Nice website.
Tom the roofer
01-18-2005, 08:40 AM
Thanks Serpent99, very nice setup. :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
