LS1 won't let me overwrite
8 SEC SLOPPY SHOT!!!
Well i went to the track with all the intenion of running my new DP setup. I made a motor pass just to make sure everything was goood to go. So now i go in the timing file and make my changes and save as an overwrite and go back into the file just to make sure everything is alright and nothing changed. now i'm pissed after doing it a couple times same ****.It just won't let me overwrite a file.I was thinking is there a update i have to buy and mine some how expired. I need to figure this out badly i've owned edit for almost two years and never had a problem any advice would be helpful
This is ls1 edit i for got to post the edit but sure most of you figure that out. I need someone to chime in if they had this problem.I can't be the only guy that had this problem
