Oversize 3-4 clutch pack/input drum anyone tried it??
Old 10-02-2004, 08:43 PM
chebby's Avatar
Default Oversize 3-4 clutch pack/input drum anyone tried it??
700R4 / 4L60E input clutch drum with 8 Super Size 6 inch clutches. A stock input drum is only large enough to hold a 5 3/4 inch clutch plate. The high performance Kevlar impregnated friction clutches are 25% thicker than a stock full thickness clutch plates and uses .060" steels. This is a full 82% larger clutch apply area compared to a stock 6 clutch drum. It has a Super Size 138 1/4 square inches of clutch apply area. This is equal to 11 stock size clutches. Even 9 thin red clutches used with 9 thin steels will only have a 50% larger apply area compared to stock and will not dissipate the heat. This input shaft and drum is sold with the 3-4 Super Size clutches and steels. It comes with a non-LS1 type input shaft, but can be converted. pics here
So this is an all new input drum??, has anyone used this part??
You can clearly see the difference in size, the frictions and steels..
