Cams Designed Around Heads
W/ bigger and bigger cams coming out each day, and alot more people going toward cam only setups, what bigger cams are out there that still make great power and work w/ say S2 5.3's or some AFR's? I see alot of people become frustrated when they put in a big cam w/ a set of heads and don't pull a lot more power out of their setup than say the other cguy w/ the same boltons and just the cam. I know that H/C needs to be matched up pretty well, and I am wanting to go b/w 232-240 I would say w/ a 4000-4400 stall/12 bolt or at least 373's, to match the H/C setup. Just kind of looking for what to stay away from and what to look for in my continuing use of the search function--I did use it--promise
