98 ls1 oil pressure sensor pin outs?
Old 10-03-2004, 01:44 PM
sr_ryan1's Avatar
Default 98 ls1 oil pressure sensor pin outs?
what pin out is for the signal? for a 98 LS1 engine, there are 2 pins
Old 10-03-2004, 09:13 PM
felton316's Avatar
Oil Level Sensor Signal is the brown wire. I'm not sure what pin that is.
Old 10-03-2004, 09:38 PM
robertbartsch's Avatar
99 has one pin only
Old 10-04-2004, 11:34 AM
sr_ryan1's Avatar
i have a painless harness it dont have a oil pressure connecter on it, so i got one from the dealership but both wires are black, i need to know the pine outs i cant go by the color, will it be okay if i just try wiring up one wire at a time till i get a signal on the guage cluster? or am i going to short somting out?
Old 10-06-2004, 09:20 AM
sr_ryan1's Avatar
bump?
Old 10-06-2004, 09:04 PM
felton316's Avatar
If it is not raining here on Friday, I'll find out for ya. That's my only day off, so that will be the only time I can get pull the sensor and check it out.
Old 10-07-2004, 08:14 AM
sr_ryan1's Avatar
okay thanks felton that would be alot of help
Old 10-09-2004, 08:53 AM
sr_ryan1's Avatar
bump??
Old 10-09-2004, 05:10 PM
felton316's Avatar
Alright, sorry for the delay. The brown wire (hell, it might be a dirty white wire from all I can tell) is the signal wire and it goes to the pin that is closest to the connector clip (the little clip you have to lift to remove the connector from the sensor). So on the sensor, it would be the pin thats closest to the little tab that the clip slides over. Am I making any sense? I tried taking photo's but they all sucked and were blurry. If you need any more info, just let me know. I might be able to try and take pics again tomorrow(Sunday).
Old 10-09-2004, 06:13 PM
sr_ryan1's Avatar
so the wire colsest to the plug clip is the signal wire, than thats all i needed to know thanks for all your help man, now if i can get this damn engine to start
