Aluminum to iron good or bad?
Old 10-04-2004, 11:42 AM
01ls1lover's Avatar
Default Aluminum to iron good or bad?
Now im lookn for a storker kit for my 01 ls1.. ive been told that the 408 iron block is the way to go but is it bad that im changing the aluminum block to an iron one? or is it not going to make a difference?
Old 10-04-2004, 12:35 PM
AllThrottleNoBottle's Avatar
It will add ~100 lbs. but most people think that the strength and potential out weights (no pun intended) the actual weight differance.
Old 10-04-2004, 01:27 PM
52172's Avatar
I would build a stroker on a ls2 aluminum 4.00 bore block that is the way to go now that the blocks are availaible.
Old 10-04-2004, 02:26 PM
01ls1lover's Avatar
how much for the block? will it make the same power as the 408? i dont know to much yet im still learning so escuse me if this is a dumb *** question..
Old 10-04-2004, 03:06 PM
goober35's Avatar
Yes if you run the same set oup on eather block they will make the same amout of power. If the LS2 block is any think like the LS1 you can not go bigger than a 4.00 bore wher in the iron block you can.
Old 10-04-2004, 04:18 PM
Worm's Avatar
I think thats the point, its NOT like the LS1 block. 4.00+ bore can be acheived.
Old 10-04-2004, 04:28 PM
sawedoff's Avatar
If the quality of your machine work is good, the LS1 engine case can handle high horsepower. I'd go with the aluminum. There's alot of positives to using an aluminum case.
Old 10-04-2004, 04:30 PM
goober35's Avatar
We will never know unless some one trys to bore the F out of the bock.
Old 10-04-2004, 04:33 PM
sawedoff's Avatar
There's so many ways to build power on an engine that there's not enough bandwidth made that'll cover it.
Old 10-04-2004, 04:38 PM
beardWS6's Avatar
I`m going 408 iron and spray the heck out of it! Gotta love it!!
Old 10-04-2004, 04:50 PM
01ls1lover's Avatar
so what would be the smart thing to do.? i hate spray.. never will use it all motor no turbos or superchargers either.
Old 10-04-2004, 05:34 PM
52172's Avatar
go with an ls2 block for sure go to the ls2 section there is someone selling them for 995.00 shipped. The post is titled ls2 blocks in stock. You could still spray the **** out of it if you were going to use N2o. I have never heard of anyone cracking an aluminum block on the juice your heads would lift off before the block got damaged.
